7-20-2011 |
1.80 |
Engine Baffle Work |
Drilled all 4 of the angle attach pieces for the side baffles. Finessed the fit of the right side baffles. Determined ultimate placement. Drilled the aft baffle holes thru the engine case; installed self-tapping screws to hold the baffle against the case firmly. Re-bent several baffle pieces in a trial and error method to get a good fit. |
