2-21-2011 |
0.70 |
Engine wiring / crankcase vent |
More parts arrived from ACS today. Mostly the 5/8" OD 5052 tube for the crankcase breather. Since it comes only in 6' lengths, I have some to play with. I cut off a small stub to make sure it fit into the breather cap OK (it did) and that it fit through the fence baffle/rubber grommet (it did). Up-drilled the fence baffle to 7/8" to hold the breather tube grommet, which also arrived today. I'm going to have to bend the tube into an S-shape, so I'm waiting until I can borrow a tubing bender. Re-routed the oil temperature sending unit wire underneath the engine. Secured it to the pushrod tubes, which Sonex said would not be too hot for the wire. |
