12-1-2010 |
1.20 |
Pushrod Length Calculation |
Spent all this time pulling the rocker arm assy on the left head on and off, on and off, to check the pushrod tool length and to set the number of spacers to ensure accurate valvetrain geometry.Finally arrived at a length that worked well across all valves on this side of the engine plus having the correct rocker-to-valve stem alignment. |
