Date:    11-17-2010
Number of Hours:    0.60
Brief Description:    Engine Mate Prep
I was going to mate the case halves tonight, but I got home from work late and really needed to take a walk / walk the dog for both of our mental well-being.
Since flange sealant is used to seal the case halves, I didn't want to get half-way through the bolt torquing sequence and have it get too late to do a proper job (as in, I'd rush if it was getting late.)
So, I prepped for tomorrow. Found all the washers, nuts, and required bolts from the hardware kit. Checked out the cam plug to determine proper installation placement (have to ask Sonex).
Made sure all bearing halves (main & cam) were correctly seated.
