Date:    11-4-2010
Number of Hours:    0.70
Brief Description:    Painted Case, Torqued Assy's
Painted the engine case. Still have to paint the accessory case flange portion.
Clamped the crank assy in the vise, used a breaker bar to remove the prop hub bolt, then applied blue loctite and torqued to 80 ft lbs as per spec.
Placed the cam gear in the vise, applied red high-strength loctite to the bold threads, and attached the cam gear to the cam. Torqued to 20 ft lbs as per spec.
