1-8-2009 |
1.30 |
Left Wing Hinges & Spar Up-drill |
Cut aileron and flap hinge halves for left wing. Up-drilled lower leading edge side of root doubler. Up-drilled lower main spar & skins to #30. Dug out SNX-W18 access hole cover from parts box. Remaining tasks for left wing box: remove LE skin; deburr, dimple skin & ribs. Pilot drill aileron & flap hinge halves to wing box. Remove upper aft skin, pilot and up-drill the aileron bellcrank stiffener brackets to the lower skin. Deburr everything else and rivet. Still haven't decided if I want to install the Duckworks landing light. I'd better decide quickly! |
