Date:    11-10-2008
Number of Hours:    1.10
Brief Description:    Right Wing Aileron Hinge Initial Fit
Measured and cut the aileron hinge halves. Marked the centerline. Clamped into position and pilot drilled to #40. Went back over it and up-drilled to #30 and cleco'd.
At this point, just have to fit the control rods to the aileron bellcrank (easier before skinning), remove the skins to deburr, then rivet. FINALLY!
