Date:    7-18-2008
Number of Hours:    1.20
Brief Description:    Riveted Elevator Control Horn
Removed cleco's; deburred, re-assembled, and riveted control horn to elevator halves. Afterward, as a test, I was able to pull both hinge pins, remove the elevator assy (surprisingly rigid), then re-install with little effort to push in the hinge pins.
