5-27-2008 |
1.10 |
Elevator Horn Work |
Obtained tight-quarters 90 degree drill adapter, threaded drill bits, and 12" drill bits from Avery today. Finished pilot drilling all elevator horns and cleco'd. Drilled 11/64" hole for the bolt that goes thru the horn & rib and into the anchor nut. Worked to ensure horn / ribs subassembly was true and didn't rock on the flat bench. |
