Date:    5-15-2008
Number of Hours:    2.70
Brief Description:    Vertical Stab Assembly
Corrected the 3 rivets from yesterday. Drilled-out and replaced. Test-fitted skin to frame; cleco'd into place, then up-drilled to #30 all aholes. Replaced hinge piece SNX-T10-06 because original one was not spaced correctly in relation to main spar.
