Productive day. On 5/2, prior entry, fab'd all detail parts for SNX-T12. Today, fabricated all detail parts for SNX-T10, channel stock for the vertical stabilizer. Progressed on to SNX-T09, where the detail parts come together for sub assemblies. Completed SNX-T09-02, the vertical stab forward spar subassembly. Moved on to SNX-T09-01, the vertical stab main spar. Drilled all pilot holes and cleco'd together SNX-T12-01, SNX-T-12-03, SNX-T12-02, and SNX-T12-04. Just have to up-drill to #30 now and rivet after deburring and cleanup. After that, work the holes for the AN3 bolts on the lower end of the vertical stab main spar.
