11-14-2011 |
3.00 |
Continued Behind-Panel Cleanup |
Worked the left side of the panel wiring. Most of the time was spent figuring out how to route the relatively shorter (compared to the right side) PTT/Freq wires to the control stick. Had to undo some of the cable ties and route the twisted pair cable along the antenna wire (don't think that will create cross-talk). Finally found an arrangement that would work. Ran out and got some new tubing for the pitot static lines; removed the Enigma from the panel to remove the old lines (just too short) and install the new tubing. Of course, in the process I stripped-out some of the JB weld globs I was using to hold the Enigma nuts in place, so I had to remove the entire panel and re-JB it. Discovered why the left side of the panel didn't fit in that well (acted like something was blocking it). The headphone jacks on the left side were actually sitting on the crosstie material that serves as the lower mounting flange for the panel material. In fact, it had bent one of the unused leads on the jack fully down. Repositioned the jack leads and filed clearance notches in the crosstie. |
