Date:    8-21-2011
Number of Hours:    1.50
Brief Description:    Hinge Work - Main Gear Leg Fairings
Drilled pilot holes in 4 hinge pieces for attachment to leg fairings.
Took stock of remaining hinge and hinge pin material, since I still have to fab 2 new hinge pins for the lower aft portion of the engine cowl (used seat pins during test fitting).
Up to this point, I had not cut the flap and aileron hinge pins to length, so I researched the plans, determined the correct lengths, and cut 4 lengths.
I then marked the set-back for the hinges to be installed on the leg fairings, and drilled/cleco'd the first hinge on each fairing.
I then installed the 2nd piece of the hinge and taped the fairing edges together. I used a blind hole locator to drill two pilot holes, establishing the position of the second hinge section. Finished drilling.
