Date:    4-27-2011
Number of Hours:    1.60
Brief Description:    Finish Cowl Centerline Trimming
Couldn't take any pictures, cuz I'd need a few more hands to hold things in place to shoot.
Spent a lot of time doing a lot of trim tonight. Trimmed the oil sump baffle on the right side. Trimmed the centerline a LOT - almost to the point where I thought I'd really be in trouble trimming too much.
Finally I remembered what Jeremy told me: "Concentrate on the corners." The other trim work was definitely needed, as I had some overlap over most of the centerline area.
The right side lower corner was a bit "thicker" than the left, so I got out the dremel and shaved it down somre more. This did the trick - the cowl centerline is now flush over its entire length.
Next up is trimming the fuel filler door and the oil cooler opening, and mounting the centerline hinges.
