9-23-2010 |
1.00 |
Countersink canopy screw holes |
Tonight I trimmed-back the protective film from around the canopy screw holes. Drilled some practice holes in a piece of scrap plexiglass and set the correct depth of my micro-stop countersink. Took some trial and error. Countersunk all screw holes. Once completed, I updrilled all holes to 9/64ths"" as per plans (so that the canopy doesn't bind and crack around rivet/screw holes). Lastly, using a cutoff wheel in my dremel, I cut the slot for the canopy latch plate and lock assembly. |
