Date:    6-17-2010
Number of Hours:    0.80
Brief Description:    Finished Panel Design
Finished marking the panel; decided to place the ELT control on the far right side of the panel, out of view in the enclosed picture. Measured some battery cable. Evaluated height needed to lift the fuselage for installing the main gear. Found the axles; removed protective covering.
