Date:    10-19-2009
Number of Hours:    1.20
Brief Description:    Motor Mount Shims
Measured and cut shims to go between the mount angles and the mount itself. The plans say that the design allows for a nominal .060 gap; I was able to use 3 shims on the upper angles and two on the lower. Looks like I will have to remove just a smidgeon more material from the lower mount angles to reduce contact area in the corners. Otherwise the fit is good.
