Date:    6-4-2009
Number of Hours:    1.70
Brief Description:    Riveted Internals
Did all the hard riveting tonight - the inside of the aft fuselage.
Riveted all formers to lower vertical channels as well as the upper splice channel.
This was a real bear due to the heat / humidity / cramped spaces. Had to drill out and replace about 8 rivets because they failed the fingernail test.
All that's remaining is to rivet the outside formers and upper longerons and then it's on to the forward fuse.
