Date:    4-10-2009
Number of Hours:    1.50
Brief Description:    Riveted Side Panels
Riveted both aft side panels. Riveted skin to lower longerons, and skins to vertical channels. Only had to drill out one rivet in the left lower longeron. Upper longeron and #1 vertical channel are not riveted until later assemblies.
Then I spent some quality time re-organizing the remaining skins which are stored on the lower shelf of my workbench. Pulled them all out, discarded no-longer-needed butcher paper layers, and re-ordered the skins bottom-to-top and improved their access from the most easy-to-reach end of the bench.
Then I dug around in the machined angle parts box and the channel bundles to get the stock I'll need for the cross-ties and other aft fuse subassemblies like the shear web, seat belt attachments, etc.
