Date:    12-11-2016
Number of Hours:    4.00
Brief Description:    Passenger Door Lock
This is a side project that I did. I wanted a cheap and easy way to lock the passenger door from inside the plane. What I ended up with was a screw that is on the outboard side of the handle, slides a piece of plastic into the gap between the steel square tube handle and the button you have to push to open the door. Simple and works.
