3-24-2015 |
10.00 |
Priming parts |
I primed several fuselage parts that had been match drilled per the plans. I tried a new method, using an HVLP gun instead of the SEM rattle cans. I had some bad luck with lifting primer, and experimented several times on scrap with results that I wasn't happy with. I will be going back to SEM rattle can for the remainder of the build. I have always had great results with it. |
