4-3-2010 |
3.00 |
Aileron Upgrade & balance |
Drilled out rivets and initial fit of gussets. Drilled first balance rib. Cut rear channel to accept balance arm. Installed protection plates on top & bottom skin. Also added 2 L angles on the front side of the rear channel to give support to the weight of the balance arm. |
