6-24-2015 |
4.00 |
Epoxied foam on left gear leg |
I applied the foam on the left gear leg. I laid out parallel strings from the gear leg back to a line that I scribed on a board under the horizontal stabilizer. I used these two strings to align the foam blocks to the airstream on the aircraft. The left side did go alot easier that the right. Practice makes perfect. |
