Date:    6-11-2015
Number of Hours:    2.00
Brief Description:    Cleaned up right gear leg fairing
The gear leg fairing is bonded to the carbon fiber. I trimmed the ends and sealed with epoxy. The picture does not do it justice. The end is slick. The epoxy is just so clear that if it were not for some of the bubbles in it you would not even know. I figured that it would be best to encapsulate each end for long term reliability. I will reinstall the brake lines once I fit the wheel pant. After I am satified with the wheel pant installation I will touch up the paint that got sanded off.
