7-5-2017 |
4.00 |
Finished heat shield on center wire bundle |
Sometimes you figure that a job is only going to take 15 minutes. Then reality set in. The heat shield fit well but the wiring harness was up against the fuel supply line. I made a new fuel supply line with an additional 1" offset. The wire is inserted in a wire loom for a finished appearance. I split the wire loom down the side and turned to the back. This will make for a neat appearance once all of the tunnel covers are made. Only about 8" of the wire will need to be covered. |
