Date:    6-24-2017
Number of Hours:    6.00
Brief Description:    Installing GPS receivers under cowl
Mounting the Garmin and Dynon GPS receivers under the cowl. I should be able to remove the oil filter with having to remove the GPS receivers. Worst case I will have to remove the four screws and move the bracket. All fits well. The receivers are spaced 12 1/2" center to center. The angle has been adjusted so that the receivers are parallel to the longitudinal axis of the plane in flight. Next step is to remove and paint.
