Date:    12-23-2014
Number of Hours:    5.00
Brief Description:    Installed elevator autopilot servo
Installed the Dynon elevator autopilot servo. Was pretty straight forward by the plans. The only problem that I see is that the pushrod needs to be about 1/2" longer. I will purchase a piece of tubing from Aircraft Spruce. I need to place an order for the flap control rods as well.
I will wait to install the connectors for servo until I place the hub. I believe that the hub can be placed on the vertical post next to the servo and I can install the serial connector to the existing length of wire on the servo.
