12-6-2014 |
4.00 |
Installed vertical stabilizer and rudder |
Installed the vertical stabilizer and rudder. Checked the elevator and rudder travel. Elevator was 29 degrees up and 22 degrees down. This is one degree less on the up and 3 degrees on the down from factory specifications. I will spend some time to get these couple of degrees back. |
