11-24-2016 |
3.00 |
Installed fuel line to prefilter |
I spent the latter part of Thanksgiving moving my wings to the airport hanger. At least I have some actual aircraft parts in the hanger that I am paying for. When I returned home I worked on installing the line from the Andair valve to the prefilter. First I safety wired the banjo fittings. Then I realized that I need to reposition the fittings. The picture that I posted was before I repositioned the fittings. Once they were repositioned I planned the fuel line run and I cut a hole to allow the fuel line access. I bent a line from the Andair valve to the prefilter. I am so glad that I can do the on the bench instead of diving into the aircraft. |
