Date:    9-25-2015
Number of Hours:    4.00
Brief Description:    Lowered the fuselage
For the past few months I had the aircraft raised as high as it would go to facilitate working on the main gear. Now that the wings and gear are complete I removed the gear and preparing to remove the wings. The wings are complete and I will put them in the wooden cradles to take to the airport once the fuselage is complete. I am removing all of the wing connections in preparation to remove the wings. Before I disconnect the flaps I do not like the angle that the flap position sensor rod makes with its pushrod. I am going to modify the bracket that I made previously. That will be for the next work session.
