5-4-2015 |
3.00 |
Adjusted aileron linkages |
In reinstalled the ailerons and checked the up and down deflections and they did not match the specifications of 15-17 degrees down and 25-30 degrees up. I scratched my head for awhile, studied the manual and the plans. I finally found on drawing 10A there is a dimension on the belcrank to the frame member of 1 3/16" while the stick is in the neutral postion. My measurement was 1". Needless to say it takes awhile to disassemble and readjust the linkages. I got all of the linkages adjusted to the plans and my measurements are both 1 3/16" and I get 15 degrees down and 28 degrees up. It is late and I will tighten allow the linkage stop nuts and reinstall the hardware and cover plates. |
