Date:    4-26-2015
Number of Hours:    5.00
Brief Description:    Work on control surfaces
Spent the day working on the remaining wing control surfaces. I installed the left flap control rods and adjusted the linkages so that they are extended to 44 degrees. I installed the safety wire on hinge pin. I fastened the hinge pin to the aileron bracket.
I then installed foam inserts into the ends of the aileron control surfaces. Once this cures I will sand them down and put a layer of fiberglass.
