Date:    3-6-2015
Number of Hours:    5.00
Brief Description:    Pressure testing left wing tank
Today I pressure tested the left tank. Had to fabricate tubing connections to manometer and to pressure tank. I found a leak on the outboard rib bottom at the back. There was a 1/8" hole in the ProSeal that I had to seal. I hope that I got all of the soapy water cleaned properly from the area. We will see tommorrow when I retest.
