2-20-2015 |
3.00 |
Install fuel return line fittings in tank |
I am planning to install the EFII fuel injection system and it requires a 3/8" fuel return to each tank. The fitting must be at least 3" from the fuel pickup to avoid entraining any air bubbles into the suction line. My setup has 5 3/4" clearance. I ProSealed the fitting on the inside and out. I am getting close to performing a pressure test on the fuel tanks. |
