10-4-2014 |
4.00 |
Cutting in Nav Lights Tip Kit |
The plan is to remove the existing side mount for the Whelen lights and install a LED Nav strobe under a lens cover on the front edge of the wing tip. Just like what is installed on current RV's. I will have to install the wing tip kit as well as repair the hole left from removing the Whelen mount. Started on the right wing tip. |
