Date:    9-10-2016
Number of Hours:    1.00
Brief Description:    Made C792
I decided to fabricate the canopy track cover C-792 from fiberglass instead of using the aluminum one in the kit. I needed it to be a little longer because my fiberglass skirt is wider than the aluminum ones in the kit. I put some black pigment in the epoxy in the event that it could be seen from inside the cockpit.
