9-19-2015 |
4.00 |
Misc loose ends on gear and wingtip |
This afternoon I bedded in the front end of the wheel pants. I applied a fiberglass cloth and then applied a cotton flox/epoxy mixture. I then installed a plate nut for the upper gear fairing in the fuselage. That one was a tricky one under the lower longeron. I then sanded down the wingtip and then applied two more layers of fiberglass. Taking the time to make it look good. |
