5-31-2015 |
2.00 |
Right brake lines |
Worked on getting the brake lines lined out. Had to disassemble the brakes to install the 90 degree fitting. I also had to remove the wheel and wheel pant bracket to get enough room to get the flaring tool in. I did the thing that everyone warns you not to do. I flared the tube without installing the nut and ferrel. |
