10-17-2011 |
7.00 |
Forward floor structure |
Match drilled floor support rails to floor structure, installed 10-32 nutplates in rails. Bolted floors to rails with AN3 bolts. Dry fit floor in forward fuselage, trimmed and sanded as required. Prepped both surfaces for bonding. Wet out both sides with straght resin. Mixed resin and Flox for build up. Built up mating surfaces with resin mixture. Installed floor structure level. Cleaned excess. |
