8-25-2011 |
4.00 |
cut outs |
Taped and measured wings for cut outs for flap brackets. Cut out using small grinder. Tape and measured trailing edges for flaps. Cut off using cutoff wheel, Sand flat with 4 foot sanding block. Tape and measured trailing edge for aileron. Used template for radius of the cut. Used a cutoff wheel, and a small soft sanding block for radius. |
