Not plane related: started making house numbers for Christmas presents. Made one oval one for my Dad and Carolyn and a square one for Tara’s sister. Tara already had the numbers painted (nice job!!) all I had to do was lay out the numbers on some wood, cut the wood, router it and then mount the numbers from the back with recessed screws and then drill mounting holes with oak plugs, coat the wood with euruthane, let it dry and then put the numbers on again and spray everything with another top coat of UV resistant sealer euruthane. Everything takes longer than you think.
