Began riveting the skin to the skeleton as per step 2, startting on leading edge rib, by the spar. Noticed that getting the last two rivets seated properly on the edge was very difficult, as the skin wouldn't lay flat. Per some nice online searches, discovered that virtually everyone had trimmed down the leading edge of these ribs to prevent a "bump". Noticed that a bump was present on the skin, but cold worked it out pretty quick. Removed all12 rivets, and began the process of fitting the skeleton appropriately. Will need to re order VS1013 due to damaged caused in the removal process (one hole elongated).
