Date:    1-5-2018
Number of Hours:    1.50
Brief Description:    Assembling the Vs
Started the process of assembling the Vertical Stabilizer today. Sorted out all the parts after I received them back from the painter and inspected the paint job, just to make sure it was all good.
While the parts got labeled, the small distinctions between parts (i.e. which VS1010 was the upper and which was the lower) were lost in the paint process. To Figure this all out, cleco'd everyting together to find the right orientation and relabled the parts as needed.
Primer on the R1007B parts was a bit thin, so I hit it quickly with a rattle can of Zinc Phosphate for good measure.
Will start riveting next time...
