5-9-2009 |
4.00 |
Deburred attach angles |
Removed the rib attach angles from the right main spar and deburred and cleaned up with the scotch brite wheel. Then I drilled out and replaced a couple of the rivets in the main spar that were bad, and then set it aside for now and going back to the left main spar. Started drilling out some of the rivets from the cap strips that I need to swicth around. |
