3-13-2009 |
7.50 |
More work on rear spars |
I made the rear spar splice plates and then pre drilled them all together so they would match up. I then drilled out the right spar caps and webbs with #30 drill bit for the 4 rivets. I pre drilled the spacer bars that go between the spar caps. |
