11-21-2009 |
2.50 |
Flight Controls |
Pg 32-02 Step 1: Bolted the VA-107 Brake Reservoir to the Firewall Upper. Pg 32-03 Step 1: Separated and deburred the F-1263A&B Flaperon Mixer Bellcranks. Step 2: Riveted the VA-146 Flange Bearings to the Flaperon Mixer Bellcranks. Step 3: Made the Flap Handle / Pushrod Assembly by threading the rod-end bearings into the ends to acheive the designated dimension, then secured the lock nuts. Pg 32-04 Step 1: Trimmed the corners from the F-1262 Flap Handle Blocks. |
