Date:    10-21-2009
Number of Hours:    1.50
Brief Description:    Fuel Tank
Pg. 37-04
Step 3: Bent the IE F-385B Float Arm to the shape of the template. Inserted Float Arm in to the Fuel Sending Unit and snapped into place.
Step 4: Temporarily attached the Res Sender Plate, Gasket and Fuel Sending Unit to the Fuel Tank Assy. Checked the clearance of the Float Arm and adjusted for clearance and travel.
