8-26-2009 |
3.00 |
Fuel Sys |
Pg. 28-05 Step 1: Installed the fuel fittings on th FLO-SCAN Fuel Flow Meter, then installed the assy. onto the FO-SCAN Mount Bracket. Step 2: Installed the fittings, plugs and drain onto the GAS-5 Gascolator. Safety wired the four screws on the Gascolator. Step 3: Installed the Gascolator to the Firewall Bottom. Installed the Straight Nipple to Pipe fluid fitting through the Firewall Bottom into the Gascolator. Step 4: Made the 8 3/4 Fuel Line Floscan-Firewall. Installed the nut and sleeve and flared the Gascolator end. Bent the tube using the template. Add nut,sleeve and flared the Floscan end. Attached the fuel line assy. |
