Date:    8-4-2009
Number of Hours:    4.50
Brief Description:    Fwd Lwr Fuse
Pg. 22-03
Step 11: Riveted the 1201L Bracket to the Tunnel Rib and with the nutplate to th Firewall Bottom. Also riveted the remaining nutplate to the Firewall Bottom.
Section 22
Deburred and primed the VA-188 Flo-scan Mount Bracket.
Pg 22-04
Step 1: MCS and riveted the nutplates to the Flo-scan Mount Bracket.
Step 2: Clecoed the Flo-scan Mount Bracket to the Fwd Fuse Floor Skin. Final-drilled #30 the attach holes and deburred the parts.
Step 3: Riveted the Flo-scan Mount Bracket to the Fwd Fuse Floor Skin.
Pg 22-05
Step 1: Clecoed and riveted the Fwd Lower Fuse Assy to the Mid Fuse and Bottom Skin Assy.
