Date:    7-2-2009
Number of Hours:    8.50
Brief Description:    Fuse MF Ribs/Bot. Skin
Section 21
Deburred two F-1203E-R Bulkhead Doublers.
Pg. 21-12
Step 1: Separated two F-1203J Bulkhead Doublers.
Deburred F1203J-L & R Bulhead Doublers.
Deburred F-1226-L & R Seat Ramp Floors.
Primed the contact surfaces of previously deburred brackets and doublers.
Pg. 21-10
Step 2: Countersunk the four holes surrouning the bearing holes on the outbd side of the Control Column Mount Brackets. Countersunk the nutplate rivet holes on each bracket.
Step 3: Riveted the bearings and spacers between the Control Column Mount Brackets forming double flush rivets around the bearings and using LP4-4 rivets for remaining holes.
